jimolson52
May 26, 2020Aspirant
Is C7000 v2 Carton Distinctively Marked?
I would like to buy a C7000 v2 at retail in a large midwestern US city. How can I determine whether the retailer's shelf inventory is the older or newer version of the C7000?
Is there a distinctive model number for the C7000 v2 marked on the retail carton?
Contact the retailer to see if there is any v2 indication on the box.
- jimolson52Aspirant
I did. The reply from two of retailer's local stores was "I dunno...we've got whatever we've got...it doesn't matter because you can always bring it back...".
> retail carton?Look for a number like "C7000-100NAS" or "C7000-200NAS". The "-1"
part denotes "v1"; the "-2", "v2". The letters vary with the region.
(And "AZ" suggests Amazon, not Arizona or Azerbaijan.)Note that a "v2" is not always an improvement over a "v1", at least
from the customer point of view. In the case of the D7000, for example,
about the best that can be said is that the D7000v2 was cheaper to
manufacture. (I don't count more and different firmware bugs as an
improvement, and a later declaration of end-of-life matters little when
the bugs don't get fixed ever, anyway.)- jimolson52Aspirant
Antinode, thanks for the good information. I wondered what the AZ was in the model number of Amazon units.
And your other comments about your D7000 experience were perceptively on target. Hope that Netgear execs read them, but I doubt it.I noticed C7000 owners/posters commenting that C7000 firmware upgrades were entirely at the discretion of their cable company, and beyond the reach of the router's owner.
> reach of the router's owner.https://kb.netgear.com/000036375
You cannot manually update your NETGEAR cable modem or modem
router's firmware.It's a DOCSIS requirement, not a Netgear requirement.
- gzimmermAspirant
I don't think that 100, 200 denotes the version. I just received a C7000-1AZNAS from Amazon and the back of the Modem says C7000v2.
> I don't think that 100, 200 denotes the version. [...]
Better evidence might justify that conclusion.
> [...] I just received a C7000-1AZNAS from Amazon [...]
Is that what the item description on the web site said, or what the
label on the factory-sealed box said, or what, exactly?> [...] and the back of the Modem says C7000v2.
Given that Netgear typically sheds all its remaining "v1" devices
when the "v2" appears, I can easily believe that you might get a "v2"
when you ask for a "v1". Even with Netgear, however, it's harder to
believe that the original box was mislabeled.
- wacouAspirant
Performance-wise, I do NOT see any real different.
Both run pretty hot. C7000 ( not version 2 ) can be laggy after long heavy usage.
But, after I added a 50x50x10mm 5V usb fan, it runs perfectly. Had not been lost connection or require reboot since.
c7000 vs v2C7000 / v2c7000c7000 v250mm 5v fan120mm guardIn operation
