JasGr81
Jan 29, 2020Aspirant
Is CM1200 a good modem to use with Velop Mesh
I have Spectrum Internet. Last summer I replaced my Apple router with 8 individual Velop nodes and it worked great for a while but then the speeds kept falling and individual nodes kept disconnecting....
- Jan 30, 2020I was in the process of posting on Linksys. But I appreciate the information about the cable splitters and the coax cable is just the cable that Spectrum installed years ago so is there a way to tell what quality it is?
antinode
Jan 29, 2020Guru
> [...] 8 individual Velop nodes [...]
Not a very detailed description of anything. Or is there only one
possible model of "Velop node"? (My quick Web search suggests
otherwise.)
> [...] I purchased the Netgear CM1200 cable modem and returned the
> Spectrum supplied modem. But it hasn't helped at all. [...]
Did you have any evidence that the modem (whatever it was) caused
your problem? Replacing one good modem with a different good modem
might reasonably be expected to have little effect on a router problem.
> [...] Does anyone know what is the recommended modem for a Velop mesh
> network [...]
Ask Linksys? Again, why blame the modem?
