orbitalpuff's avatar
Nov 30, 2023
Is CM2000 modem compatible with managed switch
My comcast business modem/router was causing issues with my VOIP.  I bought a CM2000 so that I could avoid SIP management.  When I plug the CM2000 to my managed switch my network cannot receive internet.  I connect directly to the CM2000 and there's internet.  I plug a different modem into the switch and there's internet. The only combination that does not work is the CM2000 and the switch.
I fussed with it yesterday then gave up and hired an IT company.  They are telling me the CM2000 is not compatible with my switch since it cannot generate IPs. I thought the point of the managed switch was to set the IPs for my network not the modem.  Can y'all help direct me if this is not workable? Thanks
  • plemans's avatar
    What other modem did you plug in?
    What switch do you have?
    There's different levels and some have dhcp/nat built in (basically a router built in) and then there's basic ones.
    • orbitalpuff's avatar
      orbitalpuff
      Guide
      My switch is a Zyxel GS1900-24EP. I believe it was setup with static IPs going to all the building's devices (I definitely could be wrong).  There are two WIFI Routers attached to the switch.  I have a T-Mobile 5g home internet device as a backup an that has worked at providing the switch with internet.
      • plemans's avatar
        What modem did you have before?
        You current switch is a pretty basic manager switch. It's not going to do the job by itself.. You can always call zyxel to confirm though as it's their gear. If you're trying to do a dual wan option for failover (and cheap), why not check into the edge routerx. I believe it supports both those options and is cheap.
