orbitalpuff
Nov 30, 2023Guide
Is CM2000 modem compatible with managed switch
My comcast business modem/router was causing issues with my VOIP. I bought a CM2000 so that I could avoid SIP management. When I plug the CM2000 to my managed switch my network cannot receive inter...
Dec 01, 2023Guru - Experienced User
buying a router is probably much cheaper than paying a tech to come out.
The Edge router-X's have dual wan for the failover and are really cheap.
You'd have to do a bit of research on setting up failover as it isn't just plug and play
orbitalpuff
Dec 01, 2023Guide
Thanks, I'll pick one up and give it a go!
- plemansDec 01, 2023Guru - Experienced User
If you're using that hotspot, here's their guide to use the dual wan with either load balancing or failover (falls back to the hotspot when the modem goes down)
EdgeRouter - WAN Load-Balancing – Ubiquiti Support and Help Center
- FURRYe38Dec 01, 2023Guru - Experienced User
I wish SparkLight would let me have Internet to there Hitron modem that only has phone services. Would like to try this Fail over between the Hitron and the CAX80. 🤔
