VeryBeary's avatar
VeryBeary
Is it OK to have CAX80 (Nighthawk AX6000) on its side?
I just got a Nighthawk AX6000 WiFi Cable Modem Router (model CAX80-100NAS).  I've discovered that it does not fit in its "spot" when standing upright but will if I turn it on its side.  Would it be OK to operate it this way (on its side) or would it impact performance, cooling, or any other factors?
If I have to, I can rearrange everything to make it fit standing upright but would prefer not to if not necessary.
Thank you!
AX6000 WiFi Cable Modem Router (CAX80)
  • FURRYe38's avatar
    No. Upright only.
    Cooling is a big factor there.
    • VeryBeary's avatar
      VeryBeary
      Thanks FURRYe38!  I suspected that might be the answer.  I'm already rearranging to get it to fit upright.
