BostonVicca
Jan 13, 2021Follower
Is my product still worth keeping?
Is my 2016 modem/wifi router still worth keeping, or should a new unit be considered?
Jan 13, 2021Guru - Experienced User
all depends on what you're using it for.
If its hitting the speeds you're paying for and your devices are function properly connected to it, do you NEED to upgrade or want to upgrade?
