Popo99's avatar
Popo99
Is my R7000 router with 40% signal degradation about to die?
Have this basic setup   Xfinity => CM700 (modem) => R7000 (router) =(wired)=> PC   For simplicity let's say I get 500 Mbps from Comcast. If I do the following: Xfinity => CM700 (modem) =(wired)=...
  • Kitsap's avatar
    Kitsap
    Sep 03, 2022
    Popo99 wrote:
    I then realized I had a spare Asus router, RT AC66U (comparable to the R7000). I started using it to test. Initial tests results were pretty miserable. I only got 10% (like 50 Mbps). I thought there was an issue between Asus and my Netgear modem. Since I can do anything on this router, I moved to follow @plemans to factory reset it.
    What came out was a surprise. I got 100% of the speed from Comcast.  Asus does not seem to have an app that can run Speedtest on the router, so I did the tests on the PC, which should be more "reliable". So my modem is fine. My cables are fine.
    The last thing, there is got to be something wrong with the R7000.
    It should not be a surprise.  While it is a pain, the repair value of a firmware default reset far exceeds the pain it causes.
    The design of the R7000 is several years old and many of the machines have thousands of hours of run time on them.  Like anything electronic, it ages.  Heat, voltage spikes, and power surges all take a cumulative toll on the device.  Many many R7000's are still running fine and providing good service.
