Jaimem's avatar
Jaimem
Follower
Jan 18, 2022
Is the cm1000v2 modem MoCA compatible?
Is the cm1000v2 modem MoCA or do I need to purchase separate devices. I'm trying to use the existing cable in my walls. What do you recommend for high speed MoCA devices?
1 Reply
  • plemans's avatar
    No it doesn't have integrated moca capability. You'd need to purchase that seperate
