JCS281
Oct 17, 2019Aspirant
Is the CM1100 compatible with Dlink DIR-655
Does anyone know?
Oct 17, 2019Guru - Experienced User
JCS281
It looks like it is a Rev C1
- JCS281Oct 17, 2019Aspirant
Would it be better to use the Dlink DIR-655 or the Netgear AC3600 router with the CM1100 cable modem??
- FURRYe38Oct 17, 2019Guru - Experienced User
Ok last of the 655 line. Broadcom based. I just had mine online. Worked well with my C7800 on a 200/10 ISP service.
The R7960P is a newer generation router and has a bit more features that the 655 does.
You can use LAG features between the CM1100 modem and the R7960P. Specially if you have a 1Gb service.
