mostlyrobert
Mar 14, 2021Aspirant
Is the CM1100 compatible with Intel(R) Ethernet Controller I225-V?
I connected my Intel Ethernet Controller I225-V to my CM1100 directly. I wanted to test my ISP speeds with the 2.5GBe I225-V. It would be the best way to rule out hardware limitations with a Gigabit ...
Mar 14, 2021Guru - Experienced User
When you connect this adpater to the CM modem and reboot the modem, is this adapter the only one connected to WAN port #1. IF so, then it's possible this adapter is not compatible or there maybe something with it's drivers that isn't working right with the CM1100 modem.
You'll only see 1000Mpbs on the adatper, if the adapter will connect. The CM1100 is only rated at 1000Mpbs and nothing higher.
mostlyrobert
Yeah, the ethernet adapter is the only one connected to WAN port #1 on the modem. This motherboard has one LAN port and the "Ethernet port aggregation" feature is disabled. I had to check the manual early on to see that the second WAN port supports the LAG functionality.
- FURRYe38Mar 14, 2021Guru - Experienced User
Well, if the adapter is not connecting to WAN #1 with out LAG enabled on either unit, seems like this adapter may have a problem with the CM1100. Does the adapter connect to something else like a wifi router?
- mostlyrobertMar 15, 2021Aspirant
The ethernet adapter doesn't connect. I set the speed and duplex manually to 1 Gbps and full duplex to see if that made a difference. It never picked up an address. Every other device connects to the modem without issues. I think I need to head over to the Intel forum. :smileyindifferent:
- FURRYe38Mar 15, 2021Guru - Experienced User
Ya. Good Luck.
