mostlyrobert
Mar 14, 2021Aspirant
Is the CM1100 compatible with Intel(R) Ethernet Controller I225-V?
I connected my Intel Ethernet Controller I225-V to my CM1100 directly. I wanted to test my ISP speeds with the 2.5GBe I225-V. It would be the best way to rule out hardware limitations with a Gigabit ...
mostlyrobert
Yeah, the ethernet adapter is the only one connected to WAN port #1 on the modem. This motherboard has one LAN port and the "Ethernet port aggregation" feature is disabled. I had to check the manual early on to see that the second WAN port supports the LAG functionality.
Mar 14, 2021Guru - Experienced User
Well, if the adapter is not connecting to WAN #1 with out LAG enabled on either unit, seems like this adapter may have a problem with the CM1100. Does the adapter connect to something else like a wifi router?
- mostlyrobertMar 15, 2021Aspirant
The ethernet adapter doesn't connect. I set the speed and duplex manually to 1 Gbps and full duplex to see if that made a difference. It never picked up an address. Every other device connects to the modem without issues. I think I need to head over to the Intel forum. :smileyindifferent:
- FURRYe38Mar 15, 2021Guru - Experienced User
Ya. Good Luck.
