mostlyrobert
Mar 14, 2021Aspirant
Is the CM1100 compatible with Intel(R) Ethernet Controller I225-V?
I connected my Intel Ethernet Controller I225-V to my CM1100 directly. I wanted to test my ISP speeds with the 2.5GBe I225-V. It would be the best way to rule out hardware limitations with a Gigabit ...
mostlyrobert
Mar 16, 2021Aspirant
The ethernet adapter doesn't connect. I set the speed and duplex manually to 1 Gbps and full duplex to see if that made a difference. It never picked up an address. Every other device connects to the modem without issues. I think I need to head over to the Intel forum. :smileyindifferent:
Mar 16, 2021Guru - Experienced User
Ya. Good Luck.
