WOOLYDON
Jan 16, 2022Follower
IS THE NETGEAR CM1000 MODEM COMPATABLE WITH NETGEAR NIGHTHAWK AC4000 TRI-BAND WIFI ROUTER?
I am changing internet service and I am going to supply my own DOCSIS 3.1 Modem and I have a new Nighthawk AC4000 TRI-BAND WIFI Router still in box. My question is are the Netgear CM1000 Modem caompatable with the Nighthawk AC4000 router?
Thanks, WOOLYDON
- microchip8Master
In short, yes they are. But better call up your ISP and ask which modems are on their supported list.
Yes.
Netgear has set up a community forum specifically for the Cable Modem products:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
Thanks, WOOLYDON
Please do not repost this request all over the place. Repeating the message only adds to chaos and confusion.
The answer amd advice from microchip8 is really all that you need. The modem and router will work together.
I would only add that another place to get advice might be ion the usual sales sites. Amazon, for example, will often list which Internet services the hardware supports. No need to buy there, of course, but that and reader reviews can help clear things up.
