CliffdScott
May 25, 2022Aspirant
Is the Nighthawk router/modem compatible with DSL
I bought this cable modem and then discovered that the internet line was dsl. While fiber optic cable is coming, it is slow in doing so. Thus I thought of asking a question almost surely to be answ...
michaelkenward
May 27, 2022Guru - Experienced User
Cable modems will not work on DSL and vice versa. Completely different network technologies.
Netgear has effectively ditched the DSL market, and other brands are cutting back in what they offer.
Netgear's DXXXX modem routers are for DSL. If you gave a CXXXX device that's for cable.
AT&T may have a list of compatible modems but most ISPs are technically hopeless.
Experienced users like to buy separate modems and routers. That gives them a much wider choice of router features that will sit behind any modem you like to throw at them. Unfortunately, DSL modem only devices are even harder to find than modem.routers.
- CliffdScottMay 27, 2022Aspirant
Thank you for replying to my neophyte query. I thought the answer you gave was what I would get but wanted to confirm it.
Be well,
Cliff
- michaelkenwardMay 29, 2022Guru - Experienced User
Sorry about that.
These things are sent to try us.
