OaxacaGangster
Aug 22, 2019Follower
Is the R4500 compatible with the CM1100
Hello All, I bought CM1100 cable modem. The xfinity tech who installed the modem could not get my R4500 router to work. Is the R4500 compatible with the CM1100?
Aug 22, 2019Guru - Experienced User
Power off both modem and router and connect them up. Be sure that you use Port #1 on the CM modem only. The other ports are not used for routers or other LAN devices. These are reserved for ISP assigned IP addresses.
Turn ON the modem and let it sync, the power ON the R series router. The router should get connected to the modem. It's possible a factory reset maybe needed on the router and walk thru it's setup wizard.
OaxacaGangster wrote:Hello All, I bought CM1100 cable modem. The xfinity tech who installed the modem could not get my R4500 router to work. Is the R4500 compatible with the CM1100?
