calichristina
Nov 13, 2017Aspirant
Is there a way to adjust speed on LAN jacks?
We have been using the modem just for wireless connections and just tried hooking up a PC with an ethenet jack to it. I was surprised to see the speed so slow. Is there a way to adjust the speed for the ethernet jacks?
- vkdeltaNETGEAR Employee Retired
is your ethernet 10/100 or gigabit?
- calichristinaAspirant
I'm not sure. It's Spectrum cable "Ultimate 300" so I'm guessing that is 10/100?? Thanks.
> I'm not sure. It's Spectrum cable "Ultimate 300" [...]
The question was about your hardware, not your ISP plan. "a PC with
an [E]the[r]net jack" is not a very detailed description of anything.
> [...] I was surprised to see the speed so slow. [...]
Define "so slow".
> [...] Is there a way to adjust the speed for the ethernet jacks?
Generally, no. You normally get the highest speed which the two
connected devices negotiate between themselves.
On Windows (10), perhaps: Settings > Network & Internet > Change
Adapter Options > Status would show you the Speed.
