Arnoscopy
Jul 29, 2023Follower
Is there an ethernet modem/router with controllable wifi?
I'm trying to find info on the C7000 or similar. Can the wifi be turned off while not in use? I rarely use its signal interferes with other electronics. OR is there an ethernet modem/router without ...
- Jul 29, 2023
FURRYe38 wrote:
Yes, the wifi on the C7000 can be turned OFF while using it.
Arnoscopy wrote:
I'm trying to find info on the C7000 or similar. Can the wifi be turned off while not in use? I rarely use its signal interferes with other electronics. OR is there an ethernet modem/router without wifi, that i can connect a separate router to? Thanks!
There are several ways to turn off the wifi.
As I suggested, one is a physical switch.
The others are in the manual.
michaelkenward
Jul 29, 2023Guru - Experienced User
Many Netgear router have a switch on the top that turns off the wifi.
Most also have controls in the browser graphical user interface (GUI) that can turn the wifi on and off to a schedule.
That's a new one that rely, if ever, crops up here. I'd investigate other possibilities.
There are plenty of modems out there that you can connect to the router of your choice. Look at Netgear's CM models.
That is the sort of system that many experienced users prefer. This gives them a much bigger choice of routers.
