Arnoscopy
Jul 29, 2023Follower
Is there an ethernet modem/router with controllable wifi?
I'm trying to find info on the C7000 or similar. Can the wifi be turned off while not in use? I rarely use its signal interferes with other electronics. OR is there an ethernet modem/router without ...
- Jul 29, 2023
FURRYe38 wrote:
Yes, the wifi on the C7000 can be turned OFF while using it.
Arnoscopy wrote:
I'm trying to find info on the C7000 or similar. Can the wifi be turned off while not in use? I rarely use its signal interferes with other electronics. OR is there an ethernet modem/router without wifi, that i can connect a separate router to? Thanks!
There are several ways to turn off the wifi.
As I suggested, one is a physical switch.
The others are in the manual.
schumaku
Jul 29, 2023Guru - Experienced User
Start here C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router for the complete downloads, Installation Guide, and the comprehensive complete User Manual
WiFi can be disabled and enabled with a button click...
Hope you are aware a cable modem is an RF device, creating RF noise on high bandwidth. There is even a transmitter in use for handing the uplink channels. Much more than a 2.4 GHz, 5 GHz, and even the 6 GHz Wi-Fi ever does.
