Arnoscopy
Jul 29, 2023Follower
Is there an ethernet modem/router with controllable wifi?
I'm trying to find info on the C7000 or similar. Can the wifi be turned off while not in use? I rarely use its signal interferes with other electronics. OR is there an ethernet modem/router without ...
- Jul 29, 2023
FURRYe38 wrote:
Yes, the wifi on the C7000 can be turned OFF while using it.
Arnoscopy wrote:
I'm trying to find info on the C7000 or similar. Can the wifi be turned off while not in use? I rarely use its signal interferes with other electronics. OR is there an ethernet modem/router without wifi, that i can connect a separate router to? Thanks!
There are several ways to turn off the wifi.
As I suggested, one is a physical switch.
The others are in the manual.
