retiredbgo
Sep 25, 2021Aspirant
ISP (Mediacom) will not update firmware since C7000V2 not on approved list.
I have an AC1900/C7000V2 router/modem that has the instability issues of late. I have firmware version V1.02.14 and have been trying to update to V1.03.01. This model is compatable with Mediacom...
Sep 25, 2021Guru - Experienced User
You won't be able to. Mediacom is the only one who can update it and they refuse to.
So you're kind of SOL.
That's the problem with modem/router combo devices and one of the reasons we usually push people to buy a modem seperate from the modem.
What actual issues are you have?
What makes you think upgrading firmware will fix it/
do you have a screen snip of the cable connections page and the event logs?
retiredbgo
Sep 26, 2021Aspirant
Sorry if this is bulky. I just learned what a snipping tool is. Sent emails earlier but they were returned. Hopefully this is the info you asked for.
Thanks for your help.
George Lawrence
I have been sending emails but all have been returned. Not sure if the attached photos will be present, as they are the logs you asked for.
-----Original Message-----
To: retiredbgo@aim.com
Sent: Sat, Sep 25, 2021 1:16 pm
Subject: Re: ISP (Mediacom) will not update firmware since C7000V2 not on approved list. (NETGEAR Communities Subscription Update)
- plemansSep 26, 2021Guru - Experienced User
to add them click on "choose file" and add them 1 at a time.
- retiredbgoSep 26, 2021Aspirant
I hope all the files are here. I hadded them one at a time. Thank you for your patience. This kind of stuff is ouit of my wheelhouse.
- plemansSep 27, 2021Guru - Experienced User
well you added 1 page of the "log"
Not the "event log"
Or the cable connections page.
