patches723
Mar 29, 2018Follower
ISP (RCN) won't update firmware on C6300 (AC1750) Modem
I have a C6300 AC1750 Cable modem router that has older firmware on it (currently running V1.02.21) that I'm trying to get updated to the latest version. The issue I'm running in to after reading the...
vkdelta
Mar 29, 2018NETGEAR Employee Retired
if you have friend or neighbor with Comcast connection, just take it to their home and connect to their coax line. It should automatically upgrade it self and then you can take it your home.
otherwise, RCN need to push the FW.
