gbgnyc
Aug 23, 2021Guide
ISP refuses to update frimware
I have never experienced this before. My ISP will not update the firmware. There must be a workaround? Please help
- Aug 23, 2021
but is it impacting any performance?
Stability?
Many of the modems out there are out of date because of ISP's.
If your not having issues, the firmware/security on the router/pc would be the main focus.
Aug 23, 2021Guru - Experienced User
Are you having a problem with the CM modem?
Please help
- gbgnycAug 23, 2021Guide
Yep, my little town ISP refuses to update the firmware
- FURRYe38Aug 23, 2021Guru - Experienced User
So can you give us details on whats wrong or what your experiencing with the modem?
What kind of problems are you experiencing?
FW update may not fix some problems...more details would be helpful.
ny firmware is out of date and a new version is available. It appears that only an ISP can update the software. My ISP is calle Margaretville Telecom, they will not support the hardware in any way.
