gbgnyc
Aug 23, 2021Guide
ISP refuses to update frimware
I have never experienced this before. My ISP will not update the firmware. There must be a workaround? Please help
- Aug 23, 2021
but is it impacting any performance?
Stability?
Many of the modems out there are out of date because of ISP's.
If your not having issues, the firmware/security on the router/pc would be the main focus.
gbgnyc
Sep 23, 2021Guide
Thanks for the advice. Does Netgear make a modem that allows me to update the firmware?
Sep 23, 2021Guru - Experienced User
As plemans mentioned the CAX80 and CAX30 series, users can update the "router" portion of the unit. The modem portion can not be user updated. So is something happens on the modem side, it's the ISP that still handles FW udpates on the modem side.
