skbz1999
Apr 25, 2017Tutor
ISP SuddenLink Won't Update Firmware C6300 AC1750
MODEL: C6300|AC1750 FIRMWARE: V1.02.21 HARDWARE: V3.0 WINDOWS 10 PC MACBOOK AIR OS X SIERRA AMAZON FIRE TV 2 AMAZON FIRE STICK ANDROID SMARTPHONE OS MARSHMALLOW 3 IPHONES HP OFFICEJET PRO 8...
Patyacht
Jun 22, 2017Star
Correct. We know that. BUT the problem is the ISP's deny any responsibility and thus us consumers never get our firmware updated. We the consumer need NETGEAR to be more proactive in dealing with the ISP'S to protect us the consumer. This is a pointing game in which we the consumer loses out! So NETGEAR get off your butt and fix this with the ISP's!!!!!!!!!!!!!!!!! You apparently are NOT COMMUNICATING WELL WITH THE ISP's!
Kirdro
Jul 19, 2017Star
With Suddenlink, it's even worse:
Section 37 of Suddenlink's Residential Services Agreement:
Upgrades. Customer acknowledges that the Equipment is merely a means through which the High Speed Internet Service is provided by Suddenlink and may be removed or changed by Suddenlink at its discretion as it deems appropriate, including through "uploads" to Customer's computer(s) or otherwise. Whether the cable modem is owned by Customer or Suddenlink, Suddenlink shall have the unrestricted right, but not the obligation, to upgrade the firmware in the cable modem at any time that Suddenlink, in its sole discretion, determines it is necessary or desirable. Customer assumes all responsibility for any degradation in or problems from the failure to upgrade. Suddenlink does not represent, warrant or covenant that installation and modifications of peripheral devices, including Network cards, computer equipment, software, computer files and other system configuration files necessary to operate the High Speed Internet Service will not disrupt or delay the normal operations of Customer's computer device(s) or associated equipment. Suddenlink shall have no liability whatsoever for any loss, damage or outage resulting from the above. Upon Customer request and, at Suddenlink's sole discretion, for an additional charge, Suddenlink or its agents may install certain software, an extra cable receptacle, a cable modem and associated equipment for operation of the High Speed Internet Service. If installed by Suddenlink, Suddenlink shall use reasonable efforts to install the High Speed Internet Service to a fully operational status.
Not only is Suddenlink the only one allowed to upgrade gateway devices, they place the liability on the consumer for their (suddenlink's) failure to upgrade the devices, that once again, only they (suddenlink) can upgrade.
