richeyross
Mar 01, 2021Aspirant
ISP Unable to Update CM500-100NAS Modem, Asked Me to Contact Netgear?
I've been having some issues with my internet for the past few months. There's some websites that will not load (ie gamestop.com), and I contacted my ISP today and they told me that my modem firmware...
Mar 01, 2021Guru - Experienced User
Netgear can't do anything. Its all dependant on the isp. And the isp's rarely update them.
but usually there isn't much to change with a modem.
Maybe its not the modem causing the issue?
Do you have a screen snip of the modem's cable connection page?
And the event logs?
one thing to try if your having trouble with specific websites loading, is to change your dns.
Try googles at 8.8.8.8 or 8.8.4.4
or cloudfare at 1.1.1.1
- richeyrossApr 14, 2021Aspirant
plemans wrote:Netgear can't do anything. Its all dependant on the isp. And the isp's rarely update them.
And the event logs?
Thank you for the reply. I'm hoping it's not the modem!
Thanks for the troubleshooting tips, I'd be glad to capture the screenshots. How would I access the "modem's cable connection page"? Are you referring to the 192.168.1.1 site's homepage? And how would I access the event logs? Assuming it's somewhere buried in the 192.168.1.1 site?
I will try changing my DNS to the 3 you mentioned and will see if that helps. Thanks for that recommendation as well.
- plemansApr 14, 2021Guru - Experienced User
to check the modem go to 192.168.100.1
Edit: I'm not sure why but when I upload the pictures of the event log and cable information, the pictures seem to be fine until I actually submit the comment.
