Usr184
Apr 11, 2020Guide
ISP will not update customer owned equipment
My ISP is Mediacom Cable. My cable modem is a Netgear CM600 running on an ancient firmware. My ISP will not update the firmware because I own the equipment. Netgear says they make the updated firm...
Apr 12, 2020Guru - Experienced User
Its a catch 22. damned if you do, damned if you don't.
This isn't isolated to netgear. The isp's control the firmware on all the modems connected to their service. And each time a firmware is upgraded, the ISP has to pay people to test/certify the firmware on the device. Which is why they don't like to upgrade firmware unless its causing an issue on their network. Mediacom isn't the only one doing it. They're all bad at updating the firmware on modems. Its also why I don't usually recommend modem/router combo devices either because then the router aspect of it is controlled by the isp as well.
Is there an issue you're having with the modem so that you're seeking a firmware upgrade?
Usr184
Apr 12, 2020Guide
Yes. Last week I began experiencing so many drops that I couldn't productively work from home. I called my ISP, they said there wasn't a problem on their end and since I own my own equipment there was nothing else they can/will do. In addition to the drops, now that I know Mediacom isn't updating my modem I'm now aware that there are numerous security vulnerabilities present in my existing firmware.
So it seems purchasing ones own modem is a colossal scam as you're more than likely never going to be able to update it yourself and the ISP won't update equipment they don't own. If you want any chance at receiving an update to your modem apparently the only choice is to be stuck renting equipment from an ISP. And there's still no guarantee that the ISP will maintain current firmware of it's own equipment. But since it'll be their equipment they can at least keep the customer from being able to see how far behind the equipment is, thus giving the customer the "ignorance is bliss", feeling of security.
