Usr184
Apr 11, 2020Guide
ISP will not update customer owned equipment
My ISP is Mediacom Cable. My cable modem is a Netgear CM600 running on an ancient firmware. My ISP will not update the firmware because I own the equipment. Netgear says they make the updated firm...
IowaTim
Sep 15, 2020Tutor
I am having problems. There are several advisories that are FIXED in subsequent firmware updates. I guess I'm going to remain vulnerable at the expense of corporations like NETGEAR and my ISP, Mediacom.
Sep 16, 2020Guru - Experienced User
What problems are you having?
Its not NG fault that some ISPs won't push FW to user owned modems. Ask the ISPs why they won't. I believe in history, that ISP had pushed FW to user owned modems however may have caused problems or broke there user owned modem thus causing more cost in getting the modem replaced. Now days ISPs are responsible for testing FW that comes from modem mfrs like NG and there tasked to test it before pushing it out to make sure it works and doesn't break anything on there network. Most big ISPs like CC and XF and others do this and also do push out to user owned modems. Not sure why yours won't and is probably not wanting to risk breaking anything. I Presume maybe they don't have the internal testing infrastructure that the bigger ISPs have.
If your concerned about vulnerabilities, then you may need to go with what the ISP has for there modems to keep up to date and safe if you feel this is a cause for your concern.
If the modem is having problems, then most of those problems are signal line issues that the ISP is repsonsible for making sure the signal quality up to the modem is good. You'll need to have them check this.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Good Luck.
