tbernhar
Apr 14, 2025Aspirant
issue attempting to upgrade Nighthawk cm2050v
I have an issue i've been fighting for months, latest is that my ISP (Comcast/Xfinity) says I need to upgrade the firmware on my Nighthawk CM2050V, but since I own it they will not do it. The NetGea...
michaelkenward
Apr 15, 2025Guru - Experienced User
tbernhar wrote:
I have an ongoing problem where various sites are saying that I am not in the United States (even though looking at my IP with sites such as whatismyip.com, ipchicken.com and ipinfo.io have no issues with reporting my location).
This does not smell like a modem issue. It is your router that announces your location.
The support personnel for the various sites say that Xfinity is not returning the correct info when they ask about the location of my IP.I contacted Xfinity and they say the problem is that the firmware on the modem needs to be updated, and (as of over a year ago) they no longer update the software on Customer Owned Modems.
A classic case of support passing the buck at lightning speed.
Have you tried tackling your issue at the router level?
What is that router? Anything Netgear?
Is there a solution other than finding and purchasing another Cable Modem that has the ability for me to do firmware upgrades (and I assume for $$$)..
I think you will find that there is no such thing. The ISP just wants you to rent its modem.
Disclaimer: Just another user with time on their hands.
Kitsap
Apr 15, 2025Master
Your modem is fine and firmware version 10.01.03 is the most recent. Xfinity is in the process of slow rolling activation of their Enhanced Speed Network area by area. It may take a few months for completion.
Agree with michaelkenward this points more to your router than your modem. There is a chance Xfinity has some problems with a group of WAN IP address it is using.
Suggest you change the Domain Name Server configuration in your router. Try using some of the public servers from Next, OpenDNS, Cloudflare, Google, etc. to see if the problem goes away. Be sure and configure both IPv4 and IPv6. The Xfinity default DNS servers have historically provided miserable and inconsistent service.
See attached.
- plemansApr 15, 2025Guru - Experienced User
I'd agree with checking your router and its DNS settings. Don't just check/change the IPv4 but also the IPv6. Might be why some are showing correct and others aren't.
