Abdurahmanbana
Sep 13, 2019Aspirant
Issue With My Netgear CM500 Modem
Hi, I've been having a huge issue with my modem for a year. Every night at around 8 - 11pm EST or on random parts of the day, my internet connection suddenly cuts out for 20 seconds. I managed to get...
Abdurahmanbana
Here's the other photo
Sep 13, 2019Guru - Experienced User
1 of your channels has a horrible signal with a bunch of errors in it. 1 channel isn't locking at all. Usually means something isn't set right or has interference.
A couple things you can do prior to having your isp check your line.
1. remove all splitters, amplifiers, elbows from the coax line.
2. Check all the connectors for damage, corrosion. Also look for potential spots where water could have gotten in the line. Moisture in a coax wire can create havoc
3. Move the modem to right where the coax comes into the house. this reduces the chance that its something within your house causing the issue.
4. contact your isp to check the line. many ISPs charge you if the problem is within your house. If you can reduce the chances of that (see prior suggestions) and are still having the issue, it gets the problem down to either the isp's line or potentially the modem.
- AbdurahmanbanaSep 13, 2019AspirantWhen you mean “Horrible signal/not locking” what does it mean specifically within those signals?(sorry I’m not too much of a tech guy myself but I would like to know where those signals connect) Also, I’m going to check my splitter or coaxial cables in a couple hours. Looked at almost everything but the actual splitters
So I fixed up my coax wire on the splitter I have and now my channels look a lot different. Is there a different problem with the coax now?
- FURRYe38Sep 13, 2019Guru - Experienced User
Can you remove the splitter all together and see how it does?
- plemansSep 13, 2019Guru - Experienced User
In both your images, channels 8 and 9 had the issues. The second was actually worse as there was more uncorrectables across the spectrum. I'd do like FURRYe38 says and remove the splitter if possible. If you're still having all the errors, have your isp check your line.
- AbdurahmanbanaSep 13, 2019AspirantIt might take me a day to get rid of the splitter. But if my modem works without the splitter, what does it mean for my current splitter? Do I have to get a new one or get rid of using a splitter? I currently have 2 tv cable boxes and a modem and if I don’t have a splitter, what should I do to connect them all with a secure connection?
