dbadrak
Jan 14, 2021Aspirant
Issues with firmware on RBS20 and RBR20
Hi. I went through the firmware update on my Orbi setup.
- Router RBR20, main level
- two Satellites RBS20, one upstairs and one downstairs in the basement
I can't recall the original firmware, but it was v2.3.something (unchanged from when purchased).
I changed the settings to disable daisy chaining (as this was not desired), and enabled implicit beamforming and fast roaming (expecting some performance improvements).
My first upgrade was to 2.5.1.16 on all devices. The router continues to work fine, but one of the satellites is having issues. It is dropping connections, though I can't tell if it's dropping the connection to the internet (to the RBR20). The app and web interface show it connected, and the devices are still connected to it.
This has been causing issues for everything upstairs. People connecting to the router or basement are not getting dropped.
I disabled the implicit beamforming and fast roaming, hoping that would solve it. It didn't. I left daisy chaining disabled.
I found cases of this firmware causing issues, so I did the next update 2.6.1.38 on the two satellites. The router is still on 2.5.1.16 with no issues. The upstairs continues to drop. There does not seem to be any logs I can get off the devices.
This is causing huge problems for the three people who count on that wifi to do work and school.
Is anyone else having this issue with the 2.6.1.38 firmware?
Don Badrak
You'll need to visit and post abot this over in the Orbi forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
