mrdirector
Dec 11, 2022Aspirant
Items connected to a router
I have something called BlueWizard that is connected to my router and I don't know what it is. Is there a way to find out what it is?
Dec 11, 2022Guru - Experienced User
Not much to go on.
Might search the web for this devcies.
What NG router and model # do you have?
- mrdirectorDec 11, 2022Aspirant
It's a C7000 Nighthawk.
When I pull up the list of connected devices, it says "BlueWizard" is connected. I don't know what that is and don't recall that I've connected anything called "BlueWizard." I can account for the rest of the devices. I want to find this device so I know whether to leave it connected or disconnect or block it.
- FURRYe38Dec 11, 2022Guru - Experienced User
Something you'll have to maybe turn off all devices one by one to see if it disappears from the list.
Could change the SSID name temporarily on the router as well...
Do a search online and see if you pick up anything. Try searching it's MAC address as well on the web.- mrdirectorDec 11, 2022Aspirant
Laughing at myself now. It's my wife's computer. Thanks for your input.
