BigB67
May 26, 2020Follower
JGS524 Installation
Purchased a new Netgear 24-port unmanaged switch today to replace an older one. I plugged the cable from the Xfinity modem directly into the switch and the other outgoing cables into the switch and ...
May 26, 2020Guru - Experienced User
Could be hard unless you post in the correct forum:
https://community.netgear.com/t5/Switches/ct-p/business-switches
Good Luck.
