Trixie557
Sep 20, 2020Follower
Just Looking for Recommednations
Just looking for recommendations. I purchased the CM700 High Speed Cable Modem in June 2020. I have no problem with it at all, but would like to update the Router that I am using (which is supplied...
Sep 21, 2020Guru - Experienced User
If you don't have any AX devices or support for AX wifi, you would be best served by getting into a Netgears R series or Orbi wifi mesh system. R series like R7800 to R8000 are good routers.
Other non NG router like D-LInks DIR-882 or DIR-2660 are good routers as well and 1Gb WAN To LAN supporting for fairly inexpensive routers.
Trixie557 wrote:Just looking for recommendations. I purchased the CM700 High Speed Cable Modem in June 2020. I have no problem with it at all, but would like to update the Router that I am using (which is supplied by the cable company). I just want recommendations as to which Router(s) I should consider which will be compatible with my Modem. I don't want to spend $$$, when $ or $$ will suffice. Thanks!!
