NeatGearProblem
Feb 03, 2014Aspirant
Lag spikes on CG3100
Every day I am (trying) to play games online I get huge lag spikes (999 ping), last time this happened I tried pinging, and got this result: As you are guessing this is not normal. I am using...
NeatGearProblem
Feb 07, 2014Aspirant
jmizoguchi wrote: Test the results with only single device and compare :)
I have no control over it, I'm renting a room in a house. I can't tell what makes it run smooth, and when this starts happening. But I think it usually works fine in the mornings.
And yes searay, it is supplied by the ISP I believe...
The DHCP Client Lease Info is where I can see how many devices are connected at the moment right?
