species8472jj
Oct 07, 2021Follower
LAN SetUp Address Reservation Issue
Model : CAX80 (not allowing me to enter this in)
I am having an issue trying to add devices to my Address reservation table. It is Menu Item: Advanced --- Set up --- LAN Set Up.
I added a device and the IP address did not change to the one I entered...
All the entries are ok, but the two I added turned out to be what was below when I rebooted the gateway.
31 0.0.0.0 00:00:00:00:00:00
32 0.0.0.0 00:00:00:00:00:00
I chatted with a netgear representative, and I reinstalled the firmware....I then reset the gateway to factory settings....I saved my settings and loaded that file. I then tried adding a device to that table and got the above results.
I did make sure that the address I entered was in the proper IP address range.
1 Reply
What browser are you using?
Try FireFox or MS Edge?
Doe the devices your trying to reserve appear correctly in the connected devices list?
