SoccerBall12
Mar 02, 2022Guide
LAN1, LAN2, LAN4 link down on AC1750 Firmware Version V3.01.14
Hi, my ethernet LAN1, LAN2, and LAN4 all have a status of Link Down. Lan3 is working. My router is the AC1750 WiFi cable modem model C6300. The firmware version V3.01.14. Is there a way to fix thi...
- Mar 04, 2022And if they're sending you a replacement, I'd mark this as solved so others don't try to fix a hardware failure thinking this isn't resolved. :)
SoccerBall12
Mar 02, 2022Guide
I have something plugged into Lan3 which is working. Lan1 is connected to my cable box. Lan2 to my smart TV. And lan4 an Xbox
SoccerBall12
Mar 02, 2022Guide
Even when I do not have things plugged into LAN1,2,4 they still do not work.
