SoccerBall12
Mar 02, 2022Guide
LAN1, LAN2, LAN4 link down on AC1750 Firmware Version V3.01.14
Hi, my ethernet LAN1, LAN2, and LAN4 all have a status of Link Down. Lan3 is working. My router is the AC1750 WiFi cable modem model C6300. The firmware version V3.01.14. Is there a way to fix thi...
- Mar 04, 2022And if they're sending you a replacement, I'd mark this as solved so others don't try to fix a hardware failure thinking this isn't resolved. :)
Mar 04, 2022Guru - Experienced User
If they're sending you a new one and its meeting your needs, I'd stick with it.
If/when you start looking for updates, I'd be looking at docsis 3.1 modems.
I usually advise getting modems seperate from the router. That way you control the firmware and you can upgrade one or the other without having to buy the whole unit. More expensive when you first purchase but if something goes bad or you upgrade, replacement is cheaper.
- SoccerBall12Mar 04, 2022GuideThank you for all of your help!
- plemansMar 04, 2022Guru - Experienced User
Hope the replacement works great for you!
