GoPadres
Jan 21, 2021Aspirant
Latency variation and packet loss with CM1100/Orbi RBR750 combo
Hello, I'm using a CM1100 modem and Orbi RBR750 mesh wifi system. I've been having issues with online games like Warzone and Rocket League where I get lag spikes and the "rubber banding" effect const...
- Jan 21, 2021
Coax splitters are common when the incoming cable feed must be split to serve different parts of a building. Each splitter reduces the signal strength and also adds "connections" which can work loose or become problems. A 2-way splitter reduced the signal strength by half. An 8-way splitter reduces it to 1/8th of the original level. Are there so many locations in the building needing cable service that all these splitters are necessary?
If the television "stutters", that sounds like a problem with the actual cable or connectors.
The CM1100 modem is "only a modem", so there is for sure no "Double NAT" situation. No way.
The CM1100 user manual describes how to log into the modem, check status, and look at logs.
https://www.downloads.netgear.com/files/GDC/CM1100/CM1100_All_MSOs_UM_EN.pdf
CrimpOn
Jan 21, 2021Guru - Experienced User
- GoPadresJan 22, 2021Aspirant
Ok thank you so much for this info. It seems like the 1x8 splitter is probably unnecessary, so that can go.
The double NAT was probably some kind of bug with the Xbox then, I'd assume. However, I have noticed there are two personal IP addresses when I do a pingplot or tracert, though. Is that normal?
I will look at the logs and hopefully get some useful info from them. I've seen the logs from modem before, I just wasn't able to decypher the events that were listed
- CrimpOnJan 22, 2021Guru - Experienced User
GoPadres wrote:Ok thank you so much for this info. It seems like the 1x8 splitter is probably unnecessary, so that can go.
If the CM1100 is the only device connected to the 8-way splitter, then it can be removed.
GoPadres wrote:The double NAT was probably some kind of bug with the Xbox then, I'd assume. However, I have noticed there are two personal IP addresses when I do a pingplot or tracert, though. Is that normal?
PingPlot or Trace Route from the XBox (or any other device connected to the Orbi) should show only one private IP address.
https://en.wikipedia.org/wiki/Private_network
If there are two, there is another router in the path somewhere.
p.s. When I was having an issue with theTuning Adapter that supports my Tivo, the Spectrum tech immediately cut off all the existing coax connectors and crimped on new ones. ( He also restrung the coax going up to the pole Which as it turns out, had nothing to do with the problem.) Acted like it was a standard practice.
- FURRYe38Jan 22, 2021Guru - Experienced User
What FW version do you have loaded?
There is new FW available FYI:
Ok this is crazy, I thought I had the newest FW. I did not have this installed. I'm pretty sure I am one version behind. I will update this and report back if its fixed
