dlwilladsen
Feb 17, 2025Tutor
LEDs mean what?
Power blinking green, Up,Down,Internet ALL blinking amber, Lan1/2 both solid amber? hdw v 1.0, firmware v1.3.2
- Feb 17, 2025
Can try a 30-30-30 reset on the modem to see if anything changes. If it doesn't, modem may have gone bad.
dlwilladsen
Feb 17, 2025Tutor
Manuals don't show anything near this configuration.
I'm with Mediacom. Switched to my backup modem (Motorola 7420) and all is well.
Disconnected ISP and router cables -> ends up same configuration of LEDs (pwr blinks green, down/up/internet blinks amber, Lan1/2 both solid amber.
Feb 17, 2025Guru - Experienced User
- dlwilladsenFeb 17, 2025Tutor
Must be bad then.? (tried 30-30-30 to no avail)
Thanks for the suggestions!
- FURRYe38Feb 17, 2025Guru - Experienced User
