Tee13
Sep 15, 2019Aspirant
Life span of C7000??
Any idea on lifespan of this unit? I am at 2 years 3 months and it is starting to cut out, meaning loss of wireless. Power cycling helps now and then. About ready to replace it. Is the Version 2 bette...
Sep 15, 2019Guru - Experienced User
Have you factory reset the modem and set it up from scratch?
Try placing a USB laptop cooler under the modem to keep it cooler.
Tee13
As I may have said, Newby here. Where are direction or instructions on how to do some of those things?
Thanks
Thanks
- FURRYe38Sep 15, 2019Guru - Experienced User
Please download the user manual for this modem model from here:
https://www.netgear.com/support/
User manual will have good information on how to work with the modems web page configurations.
