Golfman1007
Aug 04, 2016Aspirant
Limited or no connectivity
I recently installed a Netgear C3700 cable modem/router. I have a laptop running WIndows XP that I can't seem to get connected to the internet. I was able to connect with no problem on my older Netge...
DarrenM
Aug 08, 2016Sr. NETGEAR Moderator
Hello Golfman1007
Did you name the SSID the same name as your old router if so you will need to go into your wireless settings on your PC and tell the PC to forget all networks with that name then try to connect again.
DarrenM
- Golfman1007Aug 10, 2016Aspirant
The SSID is the name of the new router. I have other devices that connect without a problem. It is only my laptop that is running Windos XP.
