Golfman1007
Aug 04, 2016Aspirant
Limited or no connectivity
I recently installed a Netgear C3700 cable modem/router. I have a laptop running WIndows XP that I can't seem to get connected to the internet. I was able to connect with no problem on my older Netge...
R0mpetoto
Aug 11, 2016Aspirant
are you unable to connect to any website? can you login to your router?
- Golfman1007Aug 12, 2016Aspirant
I am connected to the wireless network but can not connect to any websites.
- DarrenMAug 15, 2016Sr. NETGEAR Moderator
Hello Golfman1007
Are you maybe getting a ip address conflict you usually see a yellow triangle come up on top of your wireless connection icon.
DarrenM
- Golfman1007Aug 20, 2016Aspirant
I am seeing the yellow triangle.
