Golfman1007
Aug 04, 2016Aspirant
Limited or no connectivity
I recently installed a Netgear C3700 cable modem/router. I have a laptop running WIndows XP that I can't seem to get connected to the internet. I was able to connect with no problem on my older Netge...
R0mpetoto
Aug 11, 2016Aspirant
are you unable to connect to any website? can you login to your router?
Golfman1007
Aug 12, 2016Aspirant
I am connected to the wireless network but can not connect to any websites.
- DarrenMAug 15, 2016Sr. NETGEAR Moderator
Hello Golfman1007
Are you maybe getting a ip address conflict you usually see a yellow triangle come up on top of your wireless connection icon.
DarrenM
- Golfman1007Aug 20, 2016Aspirant
I am seeing the yellow triangle.
- DarrenMAug 22, 2016Sr. NETGEAR Moderator
Hello Golfman1007
I would go into the settings of your wireless on your XP machine clear out all old wireless networks you connected to in the past and then try to connect again.
DarrenM
