sub-fr's avatar
sub-fr
Limited static IP assignment
Dear all,
I have just get the modem router Netgear N450 and I try to assign static IP following MAC address.
I did 16 IP astatic assignment but when I try to add one more I got the error message "lan address error entry"
During the troubleshooting I remove one static and add the other one with success but still failed one I go over 16 IP static.
It seems there is a limit of IP static that we can assign on the router.
Does anyone have seen this issue?
Thanks
  • Hello DarrenM
    Thanks a lot for your feedback.
    Yes I am talking about address reservations.
    There a possibility to change this?
    Why it is not specify on manual?
    Is it the same for all router or only this one?
    Thanks again
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello sub-fr
    Are you talking about the address reservation? if so then yes there is a limit on this.
    DarrenM
