NGearUser
May 13, 2017Aspirant
Limited Wifi
All the sudden the the signal strength for wifi on all our PC laptops says "Limited" and is very slow or just times out. If you run troubleshooting sometimes it says something about DCHP or bad gatew...
DarrenM
May 16, 2017Sr. NETGEAR Moderator
Hello NgearUser
It does sound like a issue with the wifi if you have factory reset the unit and still getting that issue? also have you tried a different SSID when doing the factory reset?
DarrenM
- NGearUserMay 18, 2017Aspirant
Darren,
Thanks. I have not tried chaning the SSID. Would that make a difference?
So should I change the SSID and then try my laptop and see if there are connection / speed issues?
Thanks.
OK I changed SSID and my wireless is a good connection.
So now all I need to do is restore being able to lock down the devices to just the Allow List. When I did that before my wifi and ehternet on "allowed" devices was horrible.
When I go to turn Access Control back on to allowed devices (Advanced>Advanced Setup>Wireless>) I get "Turn access control on with empty access list does not work with WPS. WPS will be inaccessible. Do you want to continue?"
I don't know what that means. We never got that message before. Advice?
- DarrenMMay 18, 2017Sr. NETGEAR Moderator
Hello NGearUser
If you do not use WPS then you should be fine in clicking continue.
DarrenM
