NGearUser
May 13, 2017Aspirant
Limited Wifi
All the sudden the the signal strength for wifi on all our PC laptops says "Limited" and is very slow or just times out. If you run troubleshooting sometimes it says something about DCHP or bad gatew...
DarrenM
May 16, 2017Sr. NETGEAR Moderator
Hello NgearUser
It does sound like a issue with the wifi if you have factory reset the unit and still getting that issue? also have you tried a different SSID when doing the factory reset?
DarrenM
NGearUser
May 18, 2017Aspirant
Darren,
Thanks. I have not tried chaning the SSID. Would that make a difference?
So should I change the SSID and then try my laptop and see if there are connection / speed issues?
Thanks.
