Soul22
Jan 07, 2021Tutor
Log codes and internet disconnections
C7800 errors and disconnects Log code says: critical 3 Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3...
Jan 07, 2021Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
Soul22
Jan 07, 2021Tutor
All of that has been done. I’m trying to determine what the critical log code 3 means and can’t find the info anywhere.
- plemansJan 07, 2021Guru - Experienced User
Take a screen snip of the full event logs as well as the cable connections page and post them back here. You'll have to do more than 1 post (use the "choose file" method or we can't see it for several days)
- Soul22Jan 07, 2021TutorFinally the ISP admitted they were having issues and there’s a known outage in my area. So it’s a a dead issue know. T3 and T4 connection issues
