Soul22
Jan 07, 2021Tutor
Log codes and internet disconnections
C7800 errors and disconnects Log code says: critical 3 Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=44:a5:6e:b4:62:48;CMTS-MAC=00:a3:d1:5d:61:5b;CM-QOS=1.1;CM-VER=3...
Soul22
Jan 07, 2021Tutor
All of that has been done. I’m trying to determine what the critical log code 3 means and can’t find the info anywhere.
- plemansJan 07, 2021Guru - Experienced User
Take a screen snip of the full event logs as well as the cable connections page and post them back here. You'll have to do more than 1 post (use the "choose file" method or we can't see it for several days)
