Lestdog
Jan 30, 2023Aspirant
Login Page for CM1000v2 just refreshes when I try to login
When I go to http://192.168.100.1. and try and login, nothing happens but a page refresh. I did a factory rest and tried "admin" & "password" and again. The page just resets the login form. Any ...
- Feb 07, 2023
Definitely check to see if you can get it RMAd. Ya seems like something is borked on the web page service side.
Good Luck.
Jan 31, 2023Guru - Experienced User
Try a different browser and/or pc.
Also, when you reset, did you push and hold for up to 15 seconds while powered on.
Lestdog
Jan 31, 2023Aspirant
Hello, thanks but yeah I did all those and just did them again. Page just refreshes and clears the login form. Any other ideas?
Thanks again.
- plemansJan 31, 2023Guru - Experienced User
make sure to have password managers disabled.
make sure there isn't any spaces in the default settings.
Also, try disconnecting the coax cable.
What browsers did you use?
- LestdogFeb 01, 2023Aspirant
Plemans, thanks again.
So I've tried:
- Edge
- Firefox (Windows)
- Opera (Windows)
- Safari on the Mac and iPhone over wifi.
I have 1password extension on Opera and Safari, but I don't think it's getting in the way.
Tried with coax cable disconnected. Same behavior.
I made a screen recording showing exactly what happens.
https://manyarms.com/netgear/netgearLogin.mp4
Thanks again for the input!
- KitsapFeb 02, 2023Master
What router brand name and model number is connected downstream from your modem?
If you are using a Windows computer, go to the network properties and make sure the network profile is private as opposed to public.
