Lestdog
Jan 30, 2023Aspirant
Login Page for CM1000v2 just refreshes when I try to login
When I go to http://192.168.100.1. and try and login, nothing happens but a page refresh. I did a factory rest and tried "admin" & "password" and again. The page just resets the login form. Any ...
- Feb 07, 2023
Definitely check to see if you can get it RMAd. Ya seems like something is borked on the web page service side.
Good Luck.
Jan 31, 2023Guru - Experienced User
make sure to have password managers disabled.
make sure there isn't any spaces in the default settings.
Also, try disconnecting the coax cable.
What browsers did you use?
Lestdog
Feb 01, 2023Aspirant
Plemans, thanks again.
So I've tried:
- Edge
- Firefox (Windows)
- Opera (Windows)
- Safari on the Mac and iPhone over wifi.
I have 1password extension on Opera and Safari, but I don't think it's getting in the way.
Tried with coax cable disconnected. Same behavior.
I made a screen recording showing exactly what happens.
https://manyarms.com/netgear/netgearLogin.mp4
Thanks again for the input!
- KitsapFeb 02, 2023Master
What router brand name and model number is connected downstream from your modem?
If you are using a Windows computer, go to the network properties and make sure the network profile is private as opposed to public.
Have you tried to connect your computer direct to the modem without any router in between?
Power down your modem and computer. Connect the computer direct to the modem and boot the modem. Wait until the modem has booted and stabilized. One of the last indicators to illuminate will be the internet connection. Wait a few minutes and boot up your computer. It may take a few minutes for your ISP to assign an IP address to your computer. Try to log in to the GUI of your modem.
- LestdogFeb 03, 2023Aspirant
Thanks Kitsap
So I gave that a go and the results are the same. There's certainly something wrong with it . It works I just can't get into the web interface. Also when I shut it down and restart, it takes several passes before it connects to the ISP. It can take up 20 minutes before it fully connects. After that it just works.
I think I can live with for the time being. Next time I go on vacation I'll send RMA it.
Thanks everyone!
